p0106, p0300
mab6680
2002 Yukon xl denali 185,*** miles
driving home the other day it starts running like crap with a blinking cel I pull over and have it towed home. the next day I hook up my scanner and get the codes p0106 and p0300. when you turn the key it will either stall right out or idle at like 400. I have changed the plugs, wires, and map sensor with no change any help would be greatfull
dgould
Same thing happens to mine when I run low on fuel. Anyone have any suggestions.
doylee4693
Tahoe User
New York
Your fuel pump works harder when you have less fuel in tank.....Its a small sign that your fuel pump will be taking a dump sooner then later.
blanchard7684
