I have a 2003 Yukon SLT 4 x 4 SLT 5.3L it's been coding for a long time and now I need an inspection. The lights been on and it's failed emissions. I have installed 4 new 02 sensors and it's coding quicker now after I clear with scanner than before. It's bank 2 that's the problem according to my scanner. I tried to see if my power brake was leaking air, I squeezed off the hose but the trims remained the same. I've checked for manifold leaks and had replaced the MAF and have cleaned it since. I noticed that the LT trim on bank 2 doesn't change it's at 25 really high. wondering if I got a bad sensor? I took a photo of the trims on my scanner at idle ( 600 RPM) and at 1500 RPM. anyone have some ideas?
