P0301
Kelsda
Kelsda
New Jersey
Heater hoses and this is in that area: https://www.rockauto.com/en/moreinfo.php?pk=84579&cc=1166431&jsn=2248
Make sure to clean off that wet area before pressure test and leave the pressure tester on there at pressure and watch for pressure drop. That weep hole at water pump can be tricky but if is leaking should leave a corrosive stain/trail.
Pressure test shows leak from radiator drivers side can’t really see where must remove to confirm weird not leaking on the ground only under 15 psi on tester, popped out twice on me. Sending antifreeze everywhere cleaned off try again tomorrow when dry test kit comes with like 20 adaptors none fit mine had to use twist lock expansion one
liquify33
Houston
The common external failure points of the intake manifold gasket are parallel to the dash in the front and back and the corners. If it’s internal your oil will look like chocolate milk
exp500
Wrap some toilet paper around the heater control valves/tees and the intake manifold Quick disconnent. If it gets wet it's easy to spot. Also bring the pressure up slow a little at a time to 15-16 max. it may start leaking at 2. I'm thinking you have a spider or lower manifold problem by your description. Is spark Bright white/blue?
Kelsda
Kelsda
New Jersey
So checking spark old screwdriver or plug ground out and look ? heater control was changed not to long ago I’m going to take out radiator leaking out of same location as yesterday lower left corner no mayo on oil cap or foam on dipstick,no fuel or antifreeze smell in oil or out of tailpipe maybe just upgrade spider and change upper and lower manifold gaskets valve covers,and thermostat all original cost maybe 700.00 in parts a few nights to do so what do you think?
liquify33
Houston
Seems the right ballpark when you factor in spider cost, the heater hose quick disconnect, a tap to repair it when it crumbles and gasket makers. 1/2” NPT, go ahead and get one now or PM me and I’ll mail you mine for $15.
The Summit/FelPro kit comes with all you need besides extra Permatex. We added orange all around the lower intake gasket where it meets the heads and manifold around the coolant passages as well as the black along the flat surfaces. Bought 1 tube each.
Spider swap is super easy with manifold off the truck.
The lower intake/spider swap is a rite of passage on these rigs:(
A small 1/4” torque wrench and a good metric set will get you there.
Extensions, socket wobble joints, a pad for the hood latch (you’ll spend a lot of time sitting on it), good lighting, beers for friends or some audiobooks if you’re solo.
If you find yourself wondering which fuel pressure regulator, the answer is either. The one with the vacuum line is for multiple vehicles, the one without a tube will also work. Make sure that’s replaced also (should come w/spider) fuel filter is also recommended.
Protect your harnesses and electronic bits from coolant and debris (don’t ask how I know).
outside of troubleshooting my own dumb mistakes, surface prep took the longest and was the least pleasant.
Kelsda
Kelsda
New Jersey
Liquify33 my apologies some how I was blocking you and someone else I reversed it took a while to figure out my i-pad screen jumps around a bit sometimes it’s frozen it’s 8 years old
east302
Mississippi
If you’re going to replace the radiator, here is a “heads up” on what not to get...
A lot of aftermarket radiators have a spare port below the radiator fill that is not used on the vortec 350. They put a rubber cap and clamp on it. It will crack and leak (100% guaranteed) which you may not notice until it’s too late. Here’s a random one from rockauto:
The Delco version matches what came from the factory and does not include the spare port. I’d recommend going with that and saving yourself the aggravation. Here’s what I used on my 98 with oil and transmission cooler connections.
GMT800 SUV/Trucks
If you do go with the aftermarket with the port, you can get clear silicone straight tubing and cut to fit with 2 clamps and use a brass plug that has serrations at the clamp area so the second clamp has some grip for the tube when plug is inserted.
east302 is correct, that rubber cap from the aftermarket supplier will leak, absolutely 100% for certain it will.
Kelsda
Kelsda
New Jersey
Thanks for information gents, going outside to start tearing down intake it’s a little cold out (30) so I’ll give it a few hours had to order the delphi FJ10566 from a friend going to take a few days for me to receive
tdeaton3
