p0446
04tahoels
i have a engine light p0446 does anyone have idea what the problems is . thanks
alacran
What needs to be changed out? I have the same problem
04tahoels
hi you need to get the updated part for the canister purge valve solenoid the one located by fuel tank not by engine the GM part number 15086768 i order it from GMPARTSGIANT.COM for $114 and it solved the p0446. if you go to dealer they want about $400-$600 to fix. just get the part and take it to your local mechanic and install and make him smoke check canister and fuel system to make sure no leaks i also recommend you order brand Oem gas cap Acdelco do not get the one with keys they always leak air.
NOS Genuine GM 15086768 Hose Evaporation Emission System
jkiger95
