P41 Stock Wheel on 99 Yukon Denali
Aggie
I want to mount the stock P41 07 - 10 Yukon Denali wheel (20 inch rim) on a 99 Yukon Denali. Has anyone had any problems (steering, braking, speedometer) mounting 275/55/20 tires to a 1999 Yukon Denali or Escalade? The factory tire size is 265/70/16. Tire would be 1.3 inches larger in diameter than stock. Thanks!
96ProCompTahoe
IN
you should be good. your may be a couple MPH off. but once you factor in tire wear and the actual tire manufacture diameter it may be less than an inch.
bufaton
