Painted interior. Wish I had not.
yukonaetahoe
yukonaetahoe
Oakland, CA
Try airplane paint remover. It should do the trick.
So I tried brake cleaner. And yes it did the trick. But oh boy took a whole 14oz can for just a 2x2 peice of plastic lol. At $4.29 a can this will be an expensive strip job.
How cost efficient is th3 airplane paint remover?
Gzes
the drifting 2dr
Wichita tx
Told ya it would work. It's an old hotrodders secret stripping method. We're you able to reuse it?
Gzes
the drifting 2dr
Wichita tx
Yea it's not bad i payed $6 for a rattle can paint stripper from Walmart when I redid my valve cover on the sol
Monstar_est87
City of Angeles
So I will strip as best as possible.
Wash with dawn and water. Dry.
Wipe down with alcohol.
Use bulldog adhesive
Spray sem black several coats
Spray 2k hardener
Spray with the flat to take down gloss.
Do I need to use a heat gun at all?
How many or how thick of adhesive coating?
And how long should the parts rest in between coats and how long before I install it? Ive hurd 24hrs
I'd also like 2 know this...
That stuff is expensive. $12 a can lol damit ima be so broke after this
Mayb a gallon of paint thiner from home depot...
Once you start modding and you get addicted, it takes your money like a stripper.
Sum1 quote in sig hahaha...
OklahomaSideShow
