Painted My Interior To Match!
95slowhoe
Boon
well i got my interior mostly painted black. And i was rereading earlier posts and on the bottom side of the cup holder is a plastic knob that you can turn and pull out and it will let you pull the cup holder off of the track. Without removing any bolts.
MotRhead
Alberta canada
i remember i painted my interior way back with Krylon for plastics , could't scratch that stuff off with a key
i would not worry to much about sanding the texture off , i would use a high build primer will save your arms some sanding time
wizzle335
Tampa
Suggestions for brands of high build primer?
97yukon
baton rouge
just your regular fill primer in a spray can , i think Dupont makes one? its been awhile
krylon makes one too....just bought some...using it for something else...no intentions of painting interior...not a fan although some do look sick...im meticulous about my shit and cant see spraying paint on the inside..imo
GMCYukalade
NC
Done my bezel few years back pretty simple lil bit of tape tho
Da90
Tulsa, OK
I painted my bezel also but I painted it to match my gray interior. It is a 99/00 Escalade bezel that was tan and I wanted the woodgrain around the outer edge where it is taped off.
gulleyman
TX.
I changed the interior of an old convertible once, found a restoration shop in town that would "dye" all the plastic and vinyl for me pretty cheap. I took all the panels off and hauled them over there, even the dash. I think it only ended up costing me about $80 to do the whole car, couldn't be much more to do a Hoe :hmm:
RepublicanRebel
