painting brake calipers
02TahoeMD
somewhere on the road
Yes, I used the Duplicolor brush on kit. Just followed directions. I borrowed a set of jackstands so I could do all four at once. Then, since it required multiple layers of paint, I started on one caliper and worked my way around the truck. By the time I was back to the starting point, the paint had set up enough to start the next coat.
blueflamed03
blueflamed03
Oklahoma
cool...Duplicolor from like a paint place, Wal-Mart? Did you use anything to clean them first?
Sasquatch
Orange County N.Y.
duplicolor has a complete kit that includes everything you need.
Customizing brake calipers is a whole lot easier. You can brush on color with Dupli-Color® High Performance Caliper Paint Kit. The complete kit includes everything you need to add color and style to your brake calipers. Available in five colors. Caliper Paint Kit goes on with a brush, so there’s no need to remove the calipers before painting. Just mask with tape and brush on color. Everything you need is included; Caliper Cleaner, stir stick, paint brush, masking tape and complete instruction book. The Caliper Paint features Ceramic Resins for maximum heat dissipation. It won’t blister, flake, crack or peel.
http://www.duplicolor.com/products/caliper.html
02TahoeMD
Yeppers, that is the kit I used. Worked fine....
Modded
That Guy
I just painted mine today, use Duplicolor Gloss Black paint with 3 coats.
I also prepped with 95% Isoporpyl alcohol to degrease and clean real good!
HMFDZ28
Hunt Sta, NY
Adding to the bandwagon... the Duplicolor brush-on kits are mint... and last quite some time. The Spray-on caliper paints dont last more then a year with still lookin good.
Your other option is Powdercoating but that gets pricey.
danimalmax
louisiana
powdercoating! why didnt i think of that before, i have all the tools in my dad's shop
withac
Eastern Idaho
I did mine on my old Durango. Masked off everything I didn't want painted, cleaned them off, threw a sheet over me and the hub so I didn't get overspray on the ride, put on a mask, sprayed with regular white primer. Let dry, hit with Duplicolor spray paint. No fancy caliper kits. Looked fine, however the Durango got totaled the next winter so I have no idea how long it would have lasted. looked good though
NJPlantman
