I would like to know if the Park Assist Module is the component that is involved in making the retrofit work. If so, do the vehicles involved have a PA Module without a certain chip or is the PA Module absent from the vehicles. Would the retrofit involve adding a chip/board to the existing module or replacing entire module? Where on the vehicle is this Module located?
update:
I've located the Park Assist Module in the rear area of the Right Quarter panel. It is visible thru the grille opening of the trim panel. There is white insulation/sound proofing sheet hanging over the grille opening which can be lifted up by inserting a thin screw driver thru the grille opening. Module has a part number on it of 86822914. Dealer service advisor is telling me they have no info of when/or how this retrofit program will happen. I presume when available, working modules will eventually be sent to dealers and owners will be notified or perhaps the opposite that notices may be sent to owners who in turn contact dealers to set up retro fit similar to recall process.
