Parking break stuck!
rando_smash
I pushed the parking break pedal to the floor and it had no resistance at all and then I tried to release it with the lever and nothing?? its on the floor and not budging... I don't think the brake works cause I drove it and its the same as before and there's no light on the dash saying it's on.. So how do I get it off the floor and back to its original spot? 2001 Tahoe LT 5.3L V8
kschumake83
Orefield, PA
I am going to take a shot in the dark here and say the cable is probably chewed up and is the reason why the pedal is stuck to the floor, and why it doesn't work either. If you replace the cable you might be good to go, depending on the quality of the parking brake shoes and components. Or if you want to half ass it just disconnect the cable from the pedal, but realize that if the brake are hanging up even a little bit there can be enough heat to start a fire at highway speeds. So please jack up the back end and make sure both tires spin freely.
Sent from my Nexus 7 using Tapatalk 2
rando_smash
rando_smash
thanks for the heads up man.. ill be sure to get it checked out. Im not the half ass type so I'm calling the garage first thing this morning.. hopefully its just the cable, ive read that it can be expensive if its too far gone
rando_smash
rando_smash
I got it looked at and mechanic said its faulty pedal and the whole assembly needs replacing.. living in Ohio its mostly flat so I'm not going to bother with it. Just wanted to update..
Wake
Stafford, VA
I'd look at a wrecking yard and get one from a donor vehicle. I don't think these things go bad too often.
Also having a parking brake is good when you actually need it. You likely will find yourself needing it on rare occasion and parking on a hill up against the parking pawl isn't good for the trans and can lock you up if enough pressure is put on it (won't be able to get out of park).
Also, if your state is like VA where I live we have vehicle inspections yearly. A non-functional or even loose parking brake will fail you here. They nailed me last year on the parking brake for being too loose and failed me.
rando_smash
rando_smash
Thanks Jim for the heads up.. ill def head to the bone yard and see if i can scoop one up.. I'm not sure if ohio does inspections or not but better to get it replaced then not just in case lol
ltcoots
