Parking light mod
Sepiroth
Sepiroth
I am here
Kouts, In
I just purchased 2 194 pigtails and 2 194 white bulbs. I spliced the 194 pigtails into the lower turn signal.
You must make sure the seal is weather tite as possible. That helps keep corrosion out.
If I wanted to do a cornering light, I coulda went with grounding one side to the body instead of using the ground supplied by the turn signal wire.
jmildoc
Indianapolis,Area
i am actually heading to the parts store today, this would be an awesome mod, I am going to make mine blink too cause my corner is amber, how did you seal up the lamp?
Sepiroth
Sepiroth
I am here
Kouts, In
The hole I drilled for the 194 socket, I used a stepper drill bit btw, and the socket itself is a rather tight weather and waterproof fit.
I suppose if you wanted to, you could use some sort of silicone to give you peace of mind.
jpmaniac87
Mississippi
Somewhat off topic, but ya'll that have done this mod would know the answer to this... Is there space in that corner light area for a strobe light that's about an inch long?
Aviator_78
