Passenger exterior door handle
PPV12HOE
NC
More than likely when the handle broke the mechanism got jammed... I would try and take a small screwdriver in the larger square hole and probe to see if you can get the mechanism to move... once it's freed up you should be able to open from the inside... then it's not to bad to replace the handle... 2 10mm bolts on the panel, 2 more 10 mm bolts on the rest of the handle, 3 t27 bolts on the latch...
I guess not completely off
intheburbs
SE MI
Any idea Why can’t I open it from inside? Are the 2 handles connected somehow
There's not a lot inside the door. I don't understand why the inside latch doesn't open the door.
Try looking for that thin vertical rod in the square opening on the left. It's about the diameter of a wire coat hanger. You'll need to grab it with needle nose/vise grips and lift it about a half inch to release the door.
If that doesn't work, here's the only other option I can think of. You're not going to like it, but it will work...But I would strongly suggest at least calling a body shop, to see if they can open it first. They'd likely charge you at most $50, if they charge you at all. If you have no luck there, here's the tactical nuke option. Make sure you already have your replacement door handle, because once you've removed the handle base, the inside of the door is now exposed to the weather.
As I mentioned, the handle is plastic, and the rest of the mechanism is metal. You'll need to pry off the remaining part of the door handle, or at least the left side by the larger square opening. The intent is to snap the plastic where the bolt is holding it in. Again, this sounds awful, but you're not going to damage anything other than the handle, which is being replaced anyway. It's a metal bolt, attached to a metal door, holding on a plastic handle. There's a metal nut insert molded into the plastic handle, and the metal nut will break out of the handle. The plastic is the weakest point and will break first. Make sure you use something under your pry bar to prevent denting the door.
Once you snap off the handle, that should expose the vertical rod to pull that up and open the door.
The reason I know this will work is that it happened another time with this truck. My daughter was walking out to get into it, and just as she grabbed the driver's door handle, she slipped on some ice and went down. Well, she instinctively grabbed the door handle harder as she went down, and snapped off the handle at the bolt. Not like what you have, the whole assembly came away from the door. So I do have a little experience at this.
Here's what the back of your handle looks like, arrow pointing to the bolt hole that needs to break...
2009_Tahoe_Owner
As has been mentioned above, it is a pretty easy fix once you have the door open and have acquired the part. The handle on my 2009 LTX simply came off in my hand when I went to open it, as there is a cheap plastic part inside that broke off. I replaced mine in about an hour start to finish following a YouTube video and using a replacement handle from 1A Auto that cost about $28. Someone trying to charge $900 for that repair is way out of bounds.
PG01
Up here to the right
Unlock the door manually, lift up the button on the door panel then open it from the inside handle
Gotcha12
