Passenger side axle shaft seal
NateDiggity
I am in the process (couple minutes each night after work) to drop and replace my wife's oil pan gasket on her 07 denali. While I am in there and have half of the front axle drooping to replace the pan I am wanting to fix her other leak, a passenger side axle shaft seal. I have never done one of these, or know much about the front IFS in general. I am wondering if this video is applicable to my vehicle. They specifically say up to 06 but was hoping it would work for the 07 as it seems to be fairly straight forward
I am having trouble finding much about the passenger side seal, and even less about the 07+'s
Is that all it takes to get it out? My only concern is the "bracket" they take off in the video, I cant quite see where its at so I will have to climb under and figure that out. Other than that though, it looks really straight forward...
It looks the same as my wife's from what I can recall (at work now) and I am wanting to replace the front fluid anyway while I have the truck down to fix other nuisances.
N
NateDiggity
Gonna have to go get a or Chilton but it appears I have to drop and split the diff to get the shaft out. I took out the bolts at the flange as well as at the diff like video showed. I can't get it to split apart fully. I can get it to pop at the diff but doesn't come out completely. There must be a clip internal to the diff..ugh and here I thought it would be easy...
N
NateDiggity
so I bought a haynes and it told me the same thing that video did...
But I have it all unbolted, and have hit the flange with a dead blow as much as I am willing to and it will split about a 1/4" at the diff but it will not come any further than that.....
Comon, sooommeeeone has had to have done this...
97ext
