Stuck in 4 wheel low
Scottydoggs
NJ
mine did this once, just had to let it sit and cool off for a few hrs, then the actuator worked again, that was in the heat of summer, during winter ive never had a issue.
PG01
Up here to the right
My Yukon is stuck in 4 wheel low. How do I get it back to 2 wheel drive? 2006 Yukon
Put it in neutral while you’re rolling foward or backwards the switch 4wd low to 4wd high…as you’re slowly moving 1-2 mph max then you should be able to go right to 2wd from there.
jeremylentsch
