Here's my problem:
Things I haven't done yet:
Anyone have any other thoughts on the issue?
The passenger taillight works intermittently. My fiancee (the driver) told me it was out, so I ran to Walmart and picked up the replacements. I took the driver's side out and replaced it (all is fine over there); took the passenger side out and replaced it (still works randomly). I did not touch the bulb while installing it (had a microfiber cloth between my skin and the bulb), I've flipped the bulb both ways that it will go in there, I've tried other bulbs that worked in other sockets. The brake-light still works, just the taillight does not.
Die-electric grease the socket, used a test light or voltmeter (am going to go pick those up after work) to check continuity to the socket.
