misfiring on driver side cylinders
irarb01
hey everyone so i got my engine swapped in my 04 tahoe it’s a 5.3 was running great for a couple weeks then all of a sudden im getting multiple cylinder miss fires on all of my my odd cylinders this engine i swapped in was a market place find. was told it had 140k on it supposedly car runs great beside mis no coolant loss or anything. only thing is when i’m accelerating you can here it popping and back firing then all of a sudden it clears up and takes off like a bat out of hell. replaced all plugs and coils and ignition wires on driver side already. still no luck.
Marky Dissod
Try swapping injectors from left to right and vice versa. If problem moves to the right side,
you need new injectors.
If problem stays on the same side, serious diagnosis required.
Donal
Americus Georgia
Check the ground cable for that side.
Before swapping the injectors why not put a noid light on them to make sure they're getting their commands?
Could also measure the voltage drop between the rail ground and the engine block, also from the rail to the battery negative. Compare driver's side to passenger side.
I
irarb01
so one thing i noticed is if i let the car warm up it will stop missing if it’s cold it will miss slightly at idle and will miss heavy under load. once its a little bit warm it will run fine under load.
afpj
Oooh, what's your fuel trims? If the driver's side bank is high positive when cold, and is better than warm, suspect intake manifold leak for a item to explore.
nonickatall
Germany
That clearly sounds like an electric problem. Did you read out the car with a scanner? You can see on which cylinders you have missfire.
If they are on all cylinders on one bank, can be the ground as already mentioned, or a clogged cat which is not very likely, when you swapped the engine. Except the old Engine had the same problems.
It can also be a lose connector on the injectors or ignition harness, or a lose or damaged ignition cable.
Did you check the ground cable as mentioned already?
Jagat4
