Passenger window
Yuk On Me
I got rained on with down windows. I rolled my passenger window up and it will not come down. Upon further investigation I found that when the switch is plugged in it automatically operates the motor and will not stop, and this is what burnt up the first window motor. Does anyone know if this is an issue with the relay or the switch? You can stop the motor if you push the switch to make the window go down but when you release the motor functions by itself. The door lock works fine.
Thanks,
mr.memo
chicago
i would think its going to be the switch maybe some corrosion in the contacts from it getting wet. or maybe the relay is sticking ??? if its on the p.s. maybe you can get the switch from one of the other pass. doors and swap see if the problem stops
WINGMAN0711
