Patch holes
tritron
How you guys fill holes left by police light. ? I have two round holes on gate in license plate area. I was thing of using a strip or cool 12" led strip. I guess for roof I am thinking on using flat shark antenna. Maybe coule short grms antennas or maybe one 5g antenna .How easy is to remove roof underlining ?
Tahoe14
Central Fl
You could use black rubber grommets that push into the hole and provide a water tight seal but you could also use a little black silicone or rtv under the grommet lip.
Sparksalot
Bastrop County, Texas
Gmrs antennas are good for the antenna holes.
The headliner isn’t hard just a PITA since a lot of interior trim has to come loose first.
Sparksalot
If you have aspirations of adding a factory roof rack, be aware they attach from below unlike previous generations.
T
tritron
what is part of roof rack rails ? If police left holes in a an b pillars . Would make sense to install usb outlets in b pillars ? Or should I use rubber plug ? They also left wires cut in botle jack tools area and big round hole any creative ideas to cover the
bhumpty1977
