Performance spark plug wires
CHOO CHOO
BackPagePhil
Manheim, Pa
So I read the sticky above and i get stay away from msd. Soooo, what do I get? I apparently have some bad wires and want to replace them with some better ones. Recommendations anyone? Its a 5.3L and I'm using E3 spark plugs.
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Sweet, isn't ac delco stock? I don't want stock or same as stock.
Sent from my DROID4 using Tapatalk 2
InTruckDesign
SW CT,
SuperChargerConnection.com get in touch with them, they have sets made up for the LS truck motors.
Bigdaddy
Michigan
I just swapped my plugs for E3 and the wires for JBL I found on EBAY for $55. Very happy with them and the smoothness of the idle.
doubletapdrew
Nothing wrong with AC Delco. A lot of the LS camaro/vette guys just use LS2 wires (on engines they've sunk thousands of dollars into upgrading). With the coil on plug systems in these Gen3 & 4 motors the wires are so short you aren't really going to notice any performance benefit from going to a more costly "low resistance" wire like you used to on distributor based engines.
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Fair enough. Seems by the concensus that stock wires are just as good. Well, they are already bought now and i am picking them up tomorrow from a fed ex shipping place.
cowboyzr2
Magnolia, TX
x3 on Delco.
I've put MSD 8.5MM on both of my trucks with good results, but am also running a MSD 6A on both of them.
I would most definitely stay away from Accel wires. A few guys I know have had bad luck with them... I bought a pair once just because they were cheap. Within a couple months 3 of them went bad.
slm987
