Hello all, new here. I have a 2010 Yukon XL 5.3 with an engine code p0010 Intake Camshaft Position Actuator Solenoid Valve Control Circuit Bank 1 that I have been chasing for a while. There is no noticeable drop in performance, but there is a drop in fuel economy. I've tried the following.
1. Fresh oil change 5w-30 mobile 1 full synthetic and Mobil 1 filter. I have always used this oil.
2. Changed camshaft position sensor.
3. Replaced the camshaft position actuator and magnet.
4. I have also replaced the pick up tube prong to fix a low oil pressure issue. Now read 60 psi cold and 35-40 full temp.
Still getting the code, not sure where to look after this. One question I had, does the vlom have anything to do with the vvt or is that only the AFM? AFM is tuned out on this vehicle.
Thank you in advance.
