Physical ethanol sensor speed?
Marky Dissod
Just guessing here but i would think that it would take a little but of time / few miles or so driving before the sensor could pick out the exact mixture given that the fuel that it’s trying to read is a liquid that’s already diluted with other grades of fuel in the tank.
It’s not like it’s trying to determine a total amount of fuel in the tank like how a float gauge would give,
it’s a specific amount of a grade of fuel it’s trying to determine.
I don’t think the reading would be instantaneous like an 02 sensor.
But this could be totally wrong, i almost feel bad posting this skimming thru some of the more knowledgeable replies.
It likely deduces the ethanol concentration after being given enough time.
It notices an O2 voltage, and makes an adjustment.
Before, when the pcm knew exactly what kind of fuel it was working with,
it understood exactly the magnitude of the effect it would have by making X amount of an adjustment.
But since it doesn't know the ethanol concentration of the fuel it's working with -
it only knows it recently refueled by more than 3 gallons, and that it should recalculate -
it eventually (re)learns the fuel that it's working with by making a fueling adjustment,
seeing how much that fueling adjustment affects things,
and the closer its adjustments meet its expectations, the better it knows what fuel it's working with.
From what I can tell, the physical sensors calculate the alcohol content using frequency, which jibes with the Tech 2 alcohol frequency info.
j91z28d1
Yes the physical sensor is in the fuel flow, it then outputs a pwm frequency to tell the ecm how much e it has. the ecm will then use it to blend the e tables and gas tables together based on that precent.
I'm pretty sure the lag you're seeing is not in the sensor output itself. other than the time it takes the fuel to mix and make it to the the sensor.
kbuskill
kbuskill
NE. FL.
being you were idling with the fuel cap off, you might have just introduce a vac leak thru the evap system changing the fuel trims. in the same way pulling the clean side air intake tube to valve cover will change trims quickly.
also if you have newer non return style fuel system. I can idle for a decent amount of time on the fuel in the rail and lines. I don't believe I've read about much lag in the sensor itself, but there will be filter settings in the ecm code. there is for almost all inputs, hpt just doesn't define everything, either because it's not normally needed to tune, or not worth the work unless requested.
I could maybe see the vacuum leak theory if the purge solenoid opened while refueling but even then it would still be pulling air through all the fuel vapors in the tank,which would be alot especially while pumping gas into the tank.
hagar
I personally think PPV nailed it with the blend time. I run a pump out splitter on e85 cars that switch between gas and e85. When i pump the gas out to nothing, then fill the tank with e85, it registers the full ratio of the e85 as soon as I turn the key back on, no delay. Haven't tried doing it without turning the key off so maybe there is something to that as well. To answer your original question though, for me, sensor instantly report back the change.
kbuskill
kbuskill
NE. FL.
Figured I would post this here just because.
First tank of E85 settled in at about 58.4%. Averaged 12.25 MPG on that tank which kind of surprised me, considering I wasn't babying it and there were a few occasions of spirited driving, because the last time I ran E85 I remember it only netted about 10ish MPG, although I'm not sure of the percentage.
I refilled the tank with 27 gallons of E85 this go around and it appears the E % is about 71-72% for this tank so we shall see what the MPG do this go around.
Marky Dissod
First tank of E85 settled in at about 58.4%. Averaged 12.25 MPG on that tank which kind of surprised me, considering I wasn't babying it,
Consider this entire post parenthetical ...
Given that 'E85' is actually E51 when it's REALLY cold out, E83 when it's REALLY hot out,
and who knows what inbetween, your numbers are no surprise.
Milkman83
Lexington, TN
I ran my first tank of e on my physical sensor a few weeks ago and it took about a mile for the % to start going up. I figured it would take a few minutes for the fuel to get up through the sensor. Filled up when I was under an 1/8 tank of 93. Went up pretty quick once it started moving. To about 69%. 2cnd tank went to 75%. I haven’t logged since then.
krbjmpr
Houston
Bit late but...
My 2012 yukon slt takes a while/ bit of a drive before I can see any change on Torque Pro. 20 minutes, 15 miles highway driving is typical, or few miles of city driving with stop lights.
I fill the tank when gets around half, per torque pro, not dash guage. Might be adding between 12 to 15 gallons to my 26 gallon tank. Fuel pump draws from bottom of tank.
Pretty sure my results are because with so much fuel left in tank, the 'new' fuel has to mix with 'old' fuel. I can plot the change over time / distance. Series of quick stop & go or lane changes accelerates change in the plot / graph (torque pro).
I have also noticed that as Ethanol % goes up, time spent in 'economy v4' decreases. Maybe because using more throttle for same driving habits. IDK. PID for throttle doesn't seem to be correct, always 25% or so. Haven't been able to find PID relating to AFM either.
Filled tank a few times intentionally with e85 from nearly empty. 24-25 gallons. Feedback yielded quick change, while fueling, to close to 80%. Conversely, same filling with straight gasoline (alcohol free) yields drop to 1%. More than once I have had my fuel paid for by Buckee's, dispensing fuel advertised as alcohol free when is E10 or E15, aka regular mix.
Oddly, Murphy / Walmart pumps typically dispense 87 that is surprisingly low in Ethanol, just a few percent. Information gathered from Torque Pro plots / graphs. Tank can reflect 3-4% Ethanol, and post fill city driving, drops to 1-2%.
T-Rain
