Pioneer 4100NEX installed
vt_hokie2008
vt_hokie2008
VA
I've done both (I'm on Android, wife is iPhone). Carplay's layout for a home screen is a bit better (shows you 6 or 8 apps to choose from) whereas Android has 5 buttons across the bottom that have apps grouped by what they do (maps, music, etc). Carplay recognizes the phone faster, but no google maps (Android Auto has gmaps). Overall both are nice and do what you want. I know Carplay is wireless now, but not on this head unit, still gotta plug in. The charging rate is only 1.6a, so my phone barely charges if playing music and barely discharges if using gmaps. I'm thinking about cutting open the usb cables and running power to it from a 12v car adapter to get fast charging.
Sent from my SM-N900V using Tapatalk
vt_hokie2008
vt_hokie2008
VA
It will, but it's like others here where it rub the dash kit & struggles a bit. I don't plan on tilting/opening it pretty much ever, so no big deal for me.
Bruizza
Planning to put one in? I can give you a parts list and everything for it. If you have Bose, which type of amp you have will determine how it has to be wired.
I would love a parts list since I plan on installing one of these this weekend!
vt_hokie2008
vt_hokie2008
VA
Aurum Ultra Series - High Speed HDMI Extension Cable Male - Female (3 Ft) with Ethernet - Supports 3D & Audio Return Channel [Latest Version] - 3 Feet https://www.amazon.com/dp/B0069A6K6I/ref=cm_sw_r_awd_EvzWvbDEY0X3Z I used this to extend my hdmi under the center console. Haven't plugged anything into it, still figuring out what to use the hdmi-in for
Metra GMOS-LAN-012 06-up GM Onstar Rentention Module https://www.amazon.com/dp/B005F4ISJQ/ref=cm_sw_r_awd_rwzWvbASQ0H3X
MXtechnic 3 Feet 1 Meter Dual USB Male to Female Extension Panel Flush Mount Cable For Car, Boat and Motorcycle https://www.amazon.com/dp/B00XL09YLW/ref=cm_sw_r_awd_5wzWvbHDA67E4 I replaced the left cigarette lighter with this. Fit pretty well and without much issue
5 pc. No-Scratch Tools for Removing Fastener & Molding https://www.amazon.com/dp/B000LNBLTK/ref=cm_sw_r_awd_FxzWvb3M9EPD4 Made things easier & no scratches
Metra 95-3305 Double DIN Installation Dash Kit for 2006-up Chevrolet Vehicles https://www.amazon.com/dp/B000K52CWO/ref=cm_sw_r_awd_4xzWvbV90GE65
Metra Axxess ASWC-1 Universal Steering Wheel Control Interface https://www.amazon.com/dp/B00B4PJC9K/ref=cm_sw_r_awd_tyzWvbPCGVG7J works mostly well, might would consider a more customizable one if doing it over
MicroBypass Parking Brake Switch Fully Automatic Video in Motion Interface for Pioneer Model AVH-4100NEX https://www.amazon.com/dp/B00VKQ6ECQ/ref=cm_sw_r_awd_UyzWvb1FJF2J1
Clarion Corporation of America CC510 Compact Automotive Color Camera with Distance Markers for CAU001 https://www.amazon.com/dp/B00B43LK7E/ref=cm_sw_r_awd_pzzWvbSCYRQ18 works well, grainy at night as they all are
t.stimpson
I need this. Google maps is way better then any gps unit I have used.
DjJayFrree
DJ to the Stars
East Bay Area RI
any more pros and cons of this unit? I just saw this post now and am looking at this vs. a OEM nav install. I'm an apple guy so want smooth nav as well as video playback.
vt_hokie2008
vt_hokie2008
VA
I can't comment on the Apple side, I'm all Android (wife has Apple, but we only hooked it up to see what it looks like). Android Auto is working well. Fingerprints are an issue as expected, the unit seems to have an issue switching to the backup camera when it should (does it 50% of the time), but otherwise I'm liking it a lot.
wiser1
