Guys, I got an '03 4x4 1500 Yukon with about 170K on it (bought it with 36K on it)
Steering system needed a go-thru of course.
I had all 4 ball joints replaced and then I replaced, myself, both wheel hub/bearings, tie-rods and pitman / idler arm, and idler arm bracket and new tires as well. Threaded the new tie-rods to same length as the old ones I pulled out and of course had it lined up after the work was done.
Long story short, it's had bump steer ever since. When you go over a rise / dip and the suspension cycles, as the front rises (suspension extends) it pulls to one side (can't remember which) and then pulls to the other side when the front compresses (suspension compresses).
I've found that with the front skid plate removed and looking through the air dam under the bumper at the centerlink, when comparing it's "levelness" to the swawbar, the crosslink is not level. It's higher on the pass side. Measuring from the concrete floor up to the bottom of the inner tie-rod, the pass side is about 1" higher than the driver side. Also, looking at the tie-rod angles, the pass side looks close to same angle as the A-arm, but the driver side looks almost flat (level).
I had the GM dealership screw up once and put a 1/2-ton idler on my 2500HD and it had same symptoms - so I know even the dealership can have a parts screwup.
The parts I put on it were ACDelco from RockAuto.
Idler Arm # 46C1120A
Idler Arm Bracket # 46C1123A
Pitman Arm # 46C0069A
I stopped at the dealership today and bought the GM Idler Arm/Bracket combo and Pitman Arm to compare to what I've got and see if one is obviously different. They were $340 and the guy said I can return them so I am trying my best to compare them and not get the new ones dirty / greasy in the process.
I'll take some pics and update in a bit, pics are worth 1000 words.
At any rate - if anyone has ran across this before, would happen to have pics of their idler / pitman or could even confirm that the crosslink DOES run level on their truck, it would be a HUGE help.
