lumberjack890
- Joined
- Mar 27, 2020
- Posts
- 67
- Reaction score
- 13
i see what's going on now, take a pair of pliers and pull that metal piece off that you show sticking out in your photo, then your actuator will go on, looks like the old actuator just came completely apart and left the gear behind. go easy and wiggle it off you don't want to break that piece that it is attached to.Might be, but every other actuator I find has that plastic piece on it.
My bad lol. The actuator is above the gas pedal.
View attachment 244659 That metal piece is what's blocking me
yes there is 2 actuators, a blower motor and a control module, that rear blower motor may also have a resistor, if you suspect the rear blower motor is out you can put 12v to it directly to test it.Yep got it off. I've put the new piece on and I finally have air blowing through after five years! This forum is absolutely fantastic!
Off topic but is there a blower motor in the rear that controls the rear A/C vents?
Not sure, but I got it to fit and everything works fine now
