For the ground wire, there is a stud right below the heater hoses. It connects to that and the frame. The second strap connects to that same frame bolt (red arrow in photo) and goes up into a sleeve near the starter (blue arrow). I couldn't tell where it went from there.
As for the distributor, it does sound like you could be at TDC for the exhaust stroke and not compression. They sell a tool with a whistle on it that sounds when the valves are closed, or just try turning the crank one revolution (aligning the marks) and try stabbing the distributor again.
Here is the procedure from the manual, maybe it will help...
INSTALLATION PROCEDURE 2
Rotate the number 1 cylinder to Top Dead Center (TDC) of the compression stroke.
Align white paint mark on the bottom stem of the distributor, and the pre-drilled indent hole in the bottom of the gear (3).
With the gear in this position, the rotor segment should be positioned as shown for a V6 engine (1) or V8 engine (2).
The alignment will not be exact.
If the driven gear is installed incorrectly, the dimple will be approximately 180 degrees opposite of the rotor segment when it is installed in the distributor.
NOTE : The OBD II ignition system distributor driven gear and rotor can be installed in multiple positions. In order to avoid mistakes, make sure to mark the distributor in the following positions:
3.1. The distributor driven gear.
3.2. The distributor shaft.
3.3. The rotor holes for the same mounting position upon reassembly.
Installing the driven gear 180 degrees out of alignment, or locating the rotor in the wrong holes, will cause a no-start condition. Premature engine wear or damage may result.
NOTE : Installing the driven gear 180 degrees out of alignment, or locating the distributor rotor in the wrong holes, may cause a no-start condition. Premature engine wear and damage may result.
Using a long screw driver, align the oil pump drive shaft to the drive tab of the distributor.
Guide the distributor into the engine. Ensure that the spark plug towers are perpendicular to the centerline of the engine.
Once the distributor is fully seated, the rotor segment should be aligned with the pointer cast into the distributor base.
This pointer may have a 6 cast into it, indicating that the distributor is to be used on a 6 cylinder engine or a 8 cast into it, indicating that the distributor is to be used on a 8 cylinder engine.
If the rotor segment does not come within a few degrees of the pointer, the gear mesh between the distributor and the camshaft may be off a tooth or more.
If this is the case, repeat the procedure again in order to achieve proper alignment.
NOTE : Refer to Fastener Notice in Cautions and Notices.
Install the distributor mounting clamp.
Tighten
Tighten the distributor clamp bolt to 25 Nm (18 lb ft) .
Install the distributor cap.
Install two NEW distributor cap screws.
Tighten
Tighten the screws to 2.4 Nm (21 lb in) .
Install the electrical connector to the distributor.
Install the spark plug wires to the distributor cap.
IMPORTANT : If the Malfunction Indicator lamp is turned on after installing the distributor, and a DTC P1345 is found, the distributor has been installed incorrectly.
Repeat INSTALLATION PROCEDURE 2 for proper distributor installation.
