please help im going crazy !!!!!! 99tahoe bad grinding
imanewb
ok it started with the front/pass wheel making a grinding noise so i figured it was time to change the rotors and pads. while doing so i had a problem with getting the front/drive rotor off. everyone and everything i looked up said it should slide off. to just give it a lil whack with a hammer. so i banged and banged away. nothing. then i put a jack in there and jacked it from the back nothing. the jack sliped out and knocked the calliper down and the center popped out. almost giving up i decide to take the nut off for the bearing. lord and behold the rotor slide off. with that settled i used a calliper kit to fix the calliper and continued to fix that side. the other side was a breeze. after bleeding the wheels i went to go test drive. it was fine besides a lil grinding,which i figured it was from the new pads. after for a few miles on a right turn i heard a pop and the grinding got worse. at high speeds it wasnt that bad but at low speeds it would sound horribble. at one point it sounded like it was rubbing agianst the tire. when i got home i took off the tire and cant see whats wrong. please help with any troubleshoots or if you know what it is. I really dont want to admit defeat and get ripped off.
Big Red
New York
Did you tighten the bearing nut down all the way to spec. If you didnt then this could be your problem. Look at all the suspension components and make sure everything you removed was put back on correctly and tight.
I
imanewb
what would be to spec..? can it be too tighten?
---------- Post added at 08:53 PM ---------- Previous post was at 08:51 PM ----------
everything else is nice and tight. im thinking the bearing went out or maybe it not in right... but it looks like it slides in no particular way as long as the nut as on tight
sleepr
Southern Ontario, Canada
There is a torque spec for basically every nut and bolt on that thing! I'm not sure at the moment what it is (my manual is in the garage), but its usually around 100 to 110? And yes you can over tighten it, if its too tight you could ruin it.
Blair
992dr
Eastern N.C.
I have used anti seize on the back of the rotors for instances like this, works great.
Tighten the bearing nut fully then back it off and finger tighten.
If they are factory bearings, its time for new ones. I have found that the tend to wear more frequently than other vehicles I have owned. Get a quality bearing greese to.
Are you sure its coming from the front?
I
imanewb
could the outer bearing brake by hitting the floor or the over tightening. i did the same on the pass side and it is fine. i just want to know what went wrong or how i can find out trouble shoot anything. if anyone has a pdf, a link, idea, solution(please), or anything please send it
---------- Post added at 09:34 PM ---------- Previous post was at 09:33 PM ----------
um im pretty sure
---------- Post added at 09:35 PM ---------- Previous post was at 09:34 PM ----------
it only makes the grind going forward too
992dr
Eastern N.C.
um im pretty sure
If they are warn and damaged, yes, they could brake after falling. Though I dont think you would brake one unless it was severely warn.
I do believe they can be damaged if you over tightened bearings.
First, I'd replace both inner and outer bearings. They are inexpensive and would at least be preventative maintanence.
Your best bet would be to get a Hanes or Chiltons book. They are pretty detailed and worth it just to have.
I agree w/ Big Red, you definately did something when you used the jack to remove your rotor. I woudlnt doubt it if you did damage a wheel bearing, inner or outer.
Good Luck
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Maybe you can get some a lot of multi angled camera shots with good calarity for us to look at? Including where the jack was supporting it.
I
imanewb
ill see about those pics in the morning...yeah i was thinking the jack broke something. what else besides the bearing could have broke? whats the piece it all slides on called...could that being bent cause the noise? thanks guys =)
NE5683
