Long time lurker and first time poster. Registered for an account tonight since I couldn't find an answer that I haven't already tried.
Backstore:
2006 Tahoe Z71 with 5.3 flex fuel
232,*** miles
I just did head gaskets, water pump, thermostat, every gasket that I could think of while in the motor, coolant flush, oil change, new belts, etc. Everything I would want a shop to do, I did it.
Everything ran great for the first 120 miles and then it started smoking. Replaced the faulty valve cover, which was the one with the outdated design, and that fixed the problem. Ran great the next 300 miles and then it started to overheat and read "coolant hot" so I shut her down and since I was a ways from home I got her towed.
Bled the system, replaced the thermostat again just in case and changed all of the fan relays as well. Idle stayed at 200-210 and then took it for a drive. Within 10 min, message popped up again that coolant was hot so I shut her down and waited til she was cold to drive her home since I was within a mile from the house.
Just replaced the thermostat again tonight with one that stays open in case of failure to cool the motor. Bled the system again and refilled to make sure there was no air bubbles. Started her up, idled for 25 min and all seemed to be good. I took her for a spin and within 2 miles it started to get higher in temps at about 250. Heater blew cold air for a little and then back to hot and then said "coolant hot" again.
I am at a loss with the rig. I am thinking maybe the brand new water pump went bad? Maybe its my fans (but they kick on as they should)? I honestly don't know.
Anybody have any thoughts on what it could be? I love the Tahoe but I am getting to the point to where I am almost ready to give it up.
Backstore:
232,*** miles
