lastmemory318
- Joined
- Jun 25, 2012
- Posts
- 6
- Reaction score
- 0
Ok, my 2000 tahoe limited recently started a "Whine" sound under the hood after 20 minutes of driving it. The whine gets louder as you accelerate. Does it while driving and while in park. ONLY does it after 20 minutes of driving, will NOT do it until you've driven it so i know its something that gets hot. Here is a list of what ive replaced trying to find this "whine".
1) Changed Both Tensioner and Idler pulley.
2) Took my 200amp Alternator off, had it tested by an Alternator shop here and they said it was fine. I put a different alternator on and it still whined. Put my original back on, still whines.
3) Took out one of my Yellow Top optima batteries (it was bad). Put brand new Optima in, charging above 14.4v now, still whines. (I run a Red Top Optima for crank and run. And a Yellow top strictly for my Audio.)
4) After that I checked and filled the Power Steering Fluid, still whines.
5) Checked and replaced Belt, still whining.
6) Changed Fan Clutch, could stop the fan with my finger while running. Still whining..
Starter was changed last month, it was dragging. Water Pump was changed out about 3 months ago, put a Flow Kooler high volume water pump on it then. Also changed the power steering pump at same time. I'm completely at a loss as to what could be making this whine sound i mean, whats left that can do it? please any insight would be greatly appreciated.
