Pop after leveling kit
Jorgez28
hi everyone I put a suspensionmaxx 2 inch leveling kit and now I have a pop coming when I turn hard left. I'm afraid it's coming from the transfer case. Anyone have an issue?
NowZoomer
I've had pops after kits, for me it was the bolts backing out so a little lock tite and proper torque solved it for me
Hope it's the same for you
Bigmac18
I've had some here and there, I thought it might be the ball joints, as mine are maxed out. Or possibly the endlinks when turning?
yates ™
Resident Apple hater
Iowa
Show pictures of the suspension after the install, you could have something in a bind.
quicksilver
Check your sway bar end links. With my lift, the bar and washers make contact until you do some trimming.
Jorgez28
Jorgez28
Thanks I will look in to it. I have a feeling it's the transmission. I hear a loud pop when moving it from park to drive
BK76
I haven't added any spacers to my '17 Hoe, but I did to my '13 Ram Diesel and I have the same sounds when turning. Always wondered if the Spacer wasn't a perfect size and so it would pop due to "lack of smooth transition" on the turns. Drives me nuts but when I take it back to the Tire shop, they say all is well and nothing is wrong.
Jorgez28
Jorgez28
So i took it to a shop and they checked it out. They did not find anything wrong but it still pops ;(
mphotsprings
