Possible driveshaft problems
tybardy
everyone needs a Hoe
Gilbert Arizona
When my truck shifts (usually at low RPM's) and even sometimes when I spike the throttle at low speeds, there is a horrible clunk underneith my truck.
Logic tells me that this is my driveshaft, but I was wondering if anyone else has had this issue and how they fixed it.
ecordell
CordellDesigns.com
Merica
May not be the drive shaft, check your u-joints and replace them to eliminate that possibility, think it could be the trans?
blueflamed03
Oklahoma
^^^ agree, sounds more like U joints. MUCH cheaper than a problem with a driveshaft.
Stick truck on flat suraface, in idle, and go from P to D, then D to R, see if it clunks while you move gears back and forth.
tybardy
tybardy
Gilbert Arizona
yes, it clunks nearly every time I put it into Drive or Reverse.
I certainly hope it is not the tranny, I will cry!
---------- Post added at 05:51 PM ---------- Previous post was at 05:51 PM ----------
how does one go about inspecting the U-Joints?
tybardy
tybardy
Gilbert Arizona
well that sounds better then the alternative... how much of a pain is it to replace? how much should I be looking to spend?
CoyotesRUS
