Power mirrors not working
Crowder99Yukon
They only work in one direction. Being down. All other directions do nothing whatsoever. Suggestions? 99 Yukon slt
Sent from my HTC One S using Tapatalk 2
Crowder99Yukon
Crowder99Yukon
Where's a good place to buy parts for these trucks?
moviewithnotitle
Jersey
I have a similar problem with my switch. But if I try the direction a few times it usually kicks in. It's touchy but eventually works. No one but me drives the truck, so once it's set, I leave it. junkyards are prbably the best place to get stuff like this. But if you want to go new, you should be able to find stuff on ebay, LMC Truck or from the dealer even.
xanatost
Lafayette, La.
If you open the switch housing you will probley find that the pad posts are broken. Go to a pull it yard and get a new pad from any chey truck. Easy fix
Crowder99Yukon
Crowder99Yukon
Just any Chevy truck will definitely not work. And ill probably end up going to a dealer as comet suggested.
Crowder99Yukon
Crowder99Yukon
Just speaking from what I've found. I've found one suburban in the three junkyards I've been in. That's the only full size Chevy suv I've been able to find. Everything else are Chevy 1500s and they're all too old. Before 96 for sure
Gzes
the drifting 2dr
Wichita tx
Well the interior changed from 95+ the 88-94 is the old style. I kinda oreffer my 94 interior than my 96 one
Torrance1978
