Power Sliding center console is loose
AngeloUCF
Hey all do you have this issue with your power sliding console where the top armrest that can extend forward doesn’t click into place? It drives me nuts when driving since it’s constantly shifting back and forth.
I can’t upload pictures or video until I get back to my PC apparently.
Not sure if this is all consoles or just a problem with mine.
Micahsd
I'll have to check. So far I've hardly moved it at all.
One thing I have noticed is the top cover piece which latches down has a rattle to it. I might have to fix that with some velcro. :)
A
AngeloUCF
Here's a video link to what I'm talking about. It's a total PITA when I'm driving around a turn and my elbow is resting on the armrest and it slides forward.
A
AngeloUCF
Bump. Can anyone with the power sliding console verify if this is standard?
Micahsd
I did play around with mine today a little and you're right that it doesn't want to stay when you slide the console back and try sliding the top part to use as an armrest.
When looking at the manual I don't see where it's supposed to lock that top part into place but it's kinda worthless if it doesn't.
Micahsd
I figured it out. It has to be slid all the way back, then the top section locks into place.
Video of mine below showing the console all the way back and how it's acting in mine.
https://1drv.ms/v/s!AjRcfHD5c6cAlKJV8eaVOZU7tm_fYw
A
AngeloUCF
Thanks for the video! Can you also confirm that it locks into place when the console is slid all the way forward and the armrest is "closed"? I can't tell by your video since it seemed to move pretty easily when you moved it forward. That's where mine is loose.
Eplion1
Mine has no wiggle or movement when all the way forward and locked into place. Strange yours allows movement when fully slid closed.
A
AngeloUCF
Thanks Eplion. I'm going to take mine in to the dealer. It's only solid when fully extended, not when closed.
Tahoeboss
Mine did that. The dealer had to order a whole new top, completely take the console apart because the cables inside were binding. They had to replace the cables also. The first top they replaced rattled and they had to order a second and rebuild it again. They had the truck 3 days. SMH
dylansmashed
