power window problem
erich7667
California
I have a 1995 GMC Yukon 4 door. My drivers side window would roll down about 4 inches then make a clicking noise. If I assisted the window by pushing down on it, it would continue to roll down. The same with rolling the window up, when it reaches that 4 inches I would have to assist it. So eventually it stop working and I bought a new switch cluster. It now works again but I still have to assist it going up and down. After saying all that today it stop working again. All of the other windows (3) go up and down using the same drivers side switch. I could use some good tips on what should I do with this delema. Thank You
erich7667
erich7667
California
Thanks for the info. I took door panel off and could clearly see the regulator jamming up. The main reason was because it was loaded with dirt and junk and wasn't moving freely. So I cleaned up everything and works fine now. Thanks again for the input.
Tssonebay
