power window...slooow
PUNKYOU007
Hopewell VA
My passenger front window will go up fine till it gets about half way then it drags ass and some times will even stop.
Bad motor?
Administrator
Sounds like the motor is about ready to die on ya.
carcrz
Georgia
Bad motor?
are your windows hooked to your alarm? just wodering because my does the same thing but i got mine hook to my alarm so i can roll it up or down with the remote
Physh1
Mine pass side has been slow since I got it & it's never gotten worse. Just in the middle of the roll-up or roll-down. I'm thinking I may just need to lubricate/clean the tracks.
Cameron
PUNKYOU007
PUNKYOU007
Hopewell VA
Guess it cant hurt to wipe the track out and lubricate it... wonder what I should use?
@carcrz no mine are not hooked up to an alarm..yet. I have everything to do it though, just cant find someone to do the install for less than $600
Administrator
I'm curious about what you'd use to lube it as well. The reason being is that my sunroof tends to stop about 3/4's the way back when opening and I have to hit the button a second time to get it to open all the way. I believe this may have to do with needing to be cleaned and lubed as well.... :shrug:
Administrator
:waytogo: awesome, I've got some of that in my garage! I'll try it this weekend on the sunroof!
02YuNali916
Sac, CA
use water, dont use grease on windows, i know you can use graphite but i forgot if its on the track or what part
pg810
