Our 2010 PPV came with a factory receiver, but it looks like it was never used. I bet he has a hitch, and the PO used it. NorCal SS speced out a 2/3 drop kit for our Tahoe. Prob the same would work for you. I just have to place the order.
Interesting...I was under the impression that non of the PPV's were equipped with hitches. I wonder if yours came from GM this way, or if it was added by the department or whoever owned it prior to you?
Also, when you say that "NORCAL SS spec'd out a 2/3 kit for our Tahoe", do you mean specifically for the PPV's? I don't see why any 2/3 kit for a standard Tahoe wouldn't work? All suspension components are interchangeable from civilian models to PPV's, so any drop kit would work unless there's something I'm missing.
That is what I was lead to think, too, but I've seen more NNBS PPVS with receiver hitches, than without. Ours came with one, and just about every one I looked at had one. Since it appears that the one on ours has never been used, I suspect they were OEM.
Yes, it is one of his standard 2/3 drop kits. Thanks.
My buddy had a PPV also. His also has helper bags. His valve was installed on the rear bumper though. Very ugly. But my guess for the helper bags would have to be due to the large steel storage bin. Mine still had it along with the cage. It took alot of work for my wife and I to pull it out due to the size and weight. If it was that heavy empty I can only imagine when it's loaded up. And yes, I'm just looking for an all around lower stance.You mean the TBSS rear bags? You have to remove your currently installed rear springs and look at the upper spring perch on both sides to make sure it has the center pilot hole and the three little notches surrounding it. These three little notches are what the TBSS rear bags use to mount. If you have them, then there's no reason why you couldn't use the bags out of a TBSS. What's your end goal? Getting the truck to sit lower all around, or just in the rear?
---------- Post added at 07:45 PM ---------- Previous post was at 07:42 PM ----------
ETA: I wonder why someone installed helper bags in your rear PPV springs? They couldn't have needed them for towing because the PPV's don't come with a trailer hitch installed unless the previous owner installed one. Or maybe they used the truck to carry serious amounts of weight in the back? Who knows... Anyway, I'd love to come across a used PPV in great shape with low miles just to keep the miles off my Suburban and use the PPV as my daily beater. Plus, I've always liked them. Especially if they're either black or white. Preferably black. I just think they have a super clean and bad ass look to them!
