Ppv tahoe parts
Lit549
I need some help,anyone ever owned a ppv Tahoe?I have a 05 that the radiator has just busted .I've had hell trying to find a replacement.I do know its a 6.0 radiator,what truck do I look up,escalade,Yukon,suburban??Thanks for any help..
I've never owned a ppv, but my I did a swap from a 4.8 to a 6.0. I later had to buy another radiator and they're all the same size--4.8, 5.3 and 6.0. Maybe go to a parts store and ask if they have any option listed for a heavy duty cooling for your year vehicle.
MINIz guy
Spectra CU2370 should be a direct fit onto your vehicle. It has all the accessories (oil cooler + trans cooler, fittings, TB coolant caps, etc) needed and is the wider 34" core.
Like Tony said, all GMT800's and 900's use a very similar radiator, and the CU2370 is made to fit all of them.
Lit549
Lit549
Ill look that up,I appreciate it..I was looking at the different radiators and several different ones came up.Oil coolers or not,trans coolers or not or both.The one I found was for an escalade .My radiator measures 34x18 1/2 x 1 5/16 which is the same as the hd radiator.I was just lost on wether It'll mount up the same..Ill check that part number you posted and see what it measures...Dam plastic tanks cracked today..
I think they all should bolt up the same way.
MINIz guy
They all mount up the same. Two bushings on the bottom and then the two bolts up top onto the front support.
Yes, there are a lot of different PN's available. I found over 10, but when you overlay them, they all have the same footprint and mounting positions. Be careful of the aluminum ones, as some have questionable fitment, from my experience. I think there should be one affordable aluminum one that will fit coming to market pretty soon.
Aren't they all aluminum? The centers anyway.
MINIz guy
Yea, the cores are usually a mix of aluminum/copper/brass. That's why they're brazed together. I was referring to the aluminum endtank ones. They usually don't come very well built, with the wrong transmission fittings, wrong endtank dimensions, and poor performing oil/trans coolers.
Lit549
Lit549
Here's the one I ordered through rockauto.The last part # ending in 115 is the I ordered.Online itsaidir was 1 5/16 thick which is what mine measures .So I get it in anditmeasures 1 1/4..Oh well,I'm running it anyways.Emailed them and they said it was packaged wrong ..
smo730
