Price on camber kit install?
Wake
Stafford, VA
What exactly is a camber kit on one of these trucks?
My Escalade it has camber adjustment, what looks like from the factory. Is this something extra you add for more angle adjustment on a lowered or lifted suspension?
I have a camber kit for my Olds that I need to install in springtime but that is simply a bolt with a cam on it, not hard to install at all.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the bushing is offset which pushes the tire out more up top.
josueh95
oh and yess the kit comes with the press tools all you need is the press
boozer
Wichita, ks
What is this Flipping of the UCA for ball joint angles? Mine are beyond normal looking.
Cant believe i have not heard of this before or forgot i did.
all you do is take then off flip them over flip the ball joint over and bolt them back up. it made a world of difference to the angle of mine. make sure to realign it. they are perfectly symetrical so they can just be flipped with no issues at all.
Tahoewhat
Ballin' on a Budget
TX
Might look into that while its in the shop for other things. Thanks
NeverSatisfied
NeverSatisfied
eBay Baller
Wichita, Kansas
Checked with summit and the belltech 4955 kit does not come with the press tool. You have to order the 4957 kit to get the tool. 4955=$67 4957=$79
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Yes thats why I sell the 4957 only with my kits.
---------- Post added at 11:24 AM ---------- Previous post was at 11:21 AM ----------
Also comes with 8 new cams
Jellis02
