Problem going backwards
Wesley e
I have a 2012 Yukon lx
Transmission seems to be working great goes into reverse. It’ll go into drive but when in reverse the vehicle moves a little and then stops as if something may be going wrong in the rear end. I don’t hear any unusual sounds. It will go forward. I even put it in neutral to try and let it roll back, and it still would stop would not roll backwards
thank you
W
Wesley e
4 wheel drive or 2? Sounds like something in the rear end or maybe in the transfer case if it's 4wd
It is two wheel drive
It will roll back about 2 foot and then it’s like something is behind the tires that it runs into
NickTransmissions
Sin City
The transmission bench
Sounds like gear train failure. Pieces of broken off gear teeth are wedging themselves into the rest of the gears, stopping the mesh and locking it up. Drop the pan and look for kibbles and bits. If observed, put the pan back on with a few bolts and yank it for overhaul.
W
Wesley e
Ok now it will go forward with no problem just not backward even with the vehicle in neutral
NickTransmissions
Sin City
Ok now drop the pan and see if there's any debris at the bottom to rule in or out the problem being transmission-related.
Alternatively, you can put the vehicle up on jackstands, disconnect the driveshaft, put the trans in neutral and see if you can spin the transmission's output shaft in either direction. If it's transmission, you'll still get that "locked up" condition. If you can spin it in both directions one full turn or so then the problem is likely elsewhere.
ETA: First - remove the driveshaft entirely and spin the rear wheels - make sure your eBrake is off. If the wheels spin freely, nothing locking them up in either direction then spin the transmission's output shaft.
W
Wesley e
Ok thank you guys so much I will keep you posted
W
Wesley e
Ok guys thank you for all your help.
So here’s what I found the drivers brake caliber bracket has two bolts holding it on, the bottom one had fell out causing the caliber to rock in drive it was good but in reverse it was getting wedged against the rotor causing it to stop the vehicle
Scpori
