Both the blend door actuator and the actuator that controls the defrost/vent/floor are not working. I thought it was weird that both actuators would go out at the same time, but I checked all the HVAC fuses and that was the best symptom I could come up with.
I recently replaced the blend door actuator and went through the reset process and nothing has changed. No movement at all on either actuator.
The problem appeared to happen soon after I replaced my factory radio for a new bluetooth stereo. I am wondering if there is some connection required between the harness that controls onstar, etc. and the temperature control module.
Rear HVAC works fine.
Any ideas?
Any ideas?
