Problem With Seperating HeadLight Lens Off Of Housing!!!!!!
wht06shee
wht06shee
well im gunna try and just use a dremel this week sometime and cut it open and see how that looks/works, if anything i might do the oem aftermarket ones MAYBE
wht06shee
wht06shee
what you think about my idea of using the projector headlights but not even run the projector at all, just use the high beam light area as my low beam??
soulsea
Bar
All that's going to happen if you buy those housings is toss them in the garbage five minutes after you fire them up. Forget the fact that they look tacky as all poop, their output is catastrophic no matter what section you use or what type of bulbs you stick in them.
That projector looking lowbeam is just molded plastic, it's not an actual projector and lacks any type of optics to project a decent low beam. That tiny high beam round reflector is barely sufficient for drl, much less an effective high beam.
No matter how you configure them, they cannot illuminate the road properly.
I'm not trying to be negative, I'm just trying to save you some money ... trust me, I tried this route myself. :Handshake:
wht06shee
wht06shee
thanks, well ill try cutting them with a dremel this week and see were that gets me, and than if it still doesnt work than ill maybe go buy the oem aftermarket ones
Dremar79
