Vigilant
- Joined
- Jun 8, 2013
- Posts
- 54
- Reaction score
- 0
I'm asking for advice from people here who have purchased the AutoCal and can speak from experience. I have all ideas that Black Bear's tuning services are top notch. The problems I am having are with the AutoCal device. I followed the instructions and hooked the device up to the diagnostic port before I cranked the engine. Even so, during the data logging process, the PCM threw an engine code. I deleted the code several times using the device, and it still persisted in coming back after about 20 minutes or so of driving. Yesterday, I disconnected the battery, tapped the brake pedal several times to drain the remaining current, and left the vehicle for right at 48 minutes before I reconnected the battery. After about 20 minutes of driving, once again, the engine light came on. Also, since shortly after I began the data logging process, the transmission has been shifting hard between first and second gear, and some times so hard that I am concerned that this process has caused permanent transmiossion damage. Has anyone else here had similar problems? If so, were they resolved with the installation of the tune, or did they continue to persist? I would like to make this work, but am concerned about possible damage to the transmission, and also to the PCM. Any thoughts y'awl can share based on your experience would be greatly appreciated.
Thanks.
Thanks.
