problems with doors not locking
Blackburban09
has anybody had this problem that the door locks dont open or close at all any imput is appriciated
and also my remote start doesnt work anymore :(
GM Customer Service
Michigan
Were you planning on having this issue addressed by your dealership? Please keep me updated when the issue has been taken care of.
Thank you,
Caron, GM Customer Service
bryanfeelsgood
Portland, OR
Thank you,
I swear that's all this guy ever says...
Do they not lock just when you're using you key fob or can you not lock/unlock from the buttons on the armrest either?
carcrz
Georgia
Thank you,
really dude is that all you got to say!!!!!!!!!!
you may need you key fob reprogramed
B
Blackburban09
it's inside the car with the key every time only 2 doors unlock or lock an no it's not the key fob
bryanfeelsgood
Portland, OR
Only thing I can think of is your door lock actuators have failed or are failing.
Doesn't explain why your remote start isn't working though. Did this all happen at the same time or has it slowly gotten worse over time?
bryanfeelsgood
Portland, OR
A quick search on GMpartsdirect.com shows them available for between $60 and $80 each. But with labor $300 sounds close for a dealer quote.
My guess is the install can't be too bad, might be worth doing yourself.
FYI, on gmpartsdirect it's Electrical > Body Electrical > Front Door > Lock Actuator
ltzhoe08
n.y.c.
Hey black burb, I had 3 replaced already and the forth just went other day. Dealer replaced my actuators . My tahoe is an 08 and it was under warranty so not sure why ur 09 should not be covered
Yukoninthedesert
