problems with doors not locking
THE YETI
Director of Operations
South FL
we had one replaced on our 08, but we have the GMPP Major Guard Warranty.
B
Blackburban09
and it turns out that if something like an emissions code is thrown the remote start no longer works
91RS
GA
Bad door lock actuators. You may call your dealer if you've been doing your service work there and see if they can goodwill them since it is a common failure (no it isn't a recall because it isn't safety). The remote start stops working if the check engine light is on, could be covered by your powertrain warranty depending on what the problem is.
1sikyukon
SFV, CA
100% your door lock actuators. Mine went out about 6 times since I had my yukon. Usually happens when you unlock the car and at the exact moment somone opens the door. It breaks the actuator. They made them soo cheap for these cars it takes very little effort to break them. Dealerships fix these left and right so they keep the parts in stock....if the car is under warranty take it in theyll have it fixed in less then an hour. If not I heard its about 200$ just for the actuator =/. Good luck
recurveman
So my wife's tahoe sounds just like yours. She has the check engine light on. I had it checked and basically the fuel overfill container???? had fuel in it and that made the check engine light come on. Didn't really plan on getting it fixed since it isn't causing any harm. Then my wife tells me that the remote start doesn't work. Well now I know why.
Her actuators are SHOT. They are complete junk in less than 3 years. We will see how that works out. $300 per door is NOT an option right now.
Thanks for the info.
Chad
---------- Post added at 10:26 PM ---------- Previous post was at 10:16 PM ----------
gmpartsdirect.com has the actuators for $140 each. You have got to be kidding me. I have a hard time believing that I'm going to spend $560 bucks for actuators for her tahoe. The worst part is knowing that you will have to spend that much money again in just a year or two.
Chad
OnE_bAd_HoE
Senior Member
Miami,Fl
i had this same problem in my 08 tahoe all 4 actuators went out a 2 months after my warrenty expired.I was told by the dealer manager that chevy does not have a recall on them but they very aware that the nnbs have a problem with the actuators failing.so a little bit of complaining and they replaced mine for free.
Yukoninthedesert
