probly not a good idea
Nickleahy23
Portage/Menomonie, WI
as long as you cut the top of the spring, its doable..not recommended though since most are progressive rate springs..cut them and see what drop you like, then order some springs..there pretty cheap..im gonna have a set of djm drop coils forsale cheap here in the near future
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
make sure to cut OFF THE TOP only. Done it many times but make sure not to cut to much because a shorter shock will be needed
jdub5256
jdub5256
J-DUB
Frederica Delaware
how much should i cut. half a ring 1 ring?? and if i do this how many miles you think this will work 100 miles 1000 miles or 10000 miles just curious.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
1 ring off top and flatten the touching edge
jdnungesser
