Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
wondering if the puddle lamp lenses are suppose to pop out from below??? i was trying and it didnt seem like it wanted to come out and i was unsure if i was doing correctly. i have a 2010 yukon denali..... thanks
If you're not careful the lens cover will come off which is annoying because they won't stick back on. It's like they're stuck on there with cheap glue.
But, yes they pop out from below. There is a tab that you push inwards and then it pulls down. Just be sure you're pulling the whole assembly, not the lens cover.
cool.... thanks alot
took 5 min or less to do both
---------- Post added at 09:51 PM ---------- Previous post was at 09:35 PM ----------
zach
what reverse lights did you get
i just installed the license plate and puddle
im still a lil weary of spending 50$ for the vleds unless theyre really worth it
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
