Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
my puddle lights don't work i checked the fuses of courtesy n all good don't know whats the problem. Also the right side of the lights where u step to get in don't work. any help will be appreciated
so i don't wanna pay for someone to fix to what i did was on the left side of the lights that u step on i connected wires on the driver side all the way up to the mirror n drilled the plastic where the puddle lights go n install a eagle eye led from ebay. I'll upload pics later in the night. But since right side of puddle n light where u step don't work i can't do nothing.
Well you better hope if there's ever a problem that fuse will blow, because if those wires get caught in the door hinge it will start a fire... you really should go about that a different way. Running the wires through the door boot would be best.
So you ran wires through the door, cut apart the OEM puddle lights and put new lights in it's place, and have electrical taped the wires together hanging down?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
