Putco Nite-Lux LED Foglight Install
JayW
JayW
Cool, I look forward to seeing your comparison of LED vs. HID on the low beams. I think the swap of the high beams is a no-brainer, but anxious to see that too.
damitchell
Yea,,,, they are pretty bright fogs for sure... will do shots from same locations once I get the new LED ones in...
OEM HID Lows and Halogen Highs
OEM HID Lows
OEM HID Lows and Putco LED Fogs
OEM HID Lows
damitchell
Ok bad news for you Denali owners... guess I should have seen/connected the dots... the bulbs I ordered for the low beams.. (H11) do not fit the 2016 yukon Denali low beams. The Denali has HIDs with D3S 4 pin green connectors. I called Putco and they said they don't make one for my vehicle. I challenged them a little on their website and Amazon saying they would fit and they suggested their website is really a guide but we the end user has to know the connector pin type. Fair enough... should have known that I guess. No big... requested a RMA on Amazon already. High beam LEDs will be here tomorrow and will update you.
Ohhh,, fYI,,, if you take out the HID bulb,,, its a trick to get it back in... the tabs have on the lamp collar have to be aligned just right and flush in order for you to spin it clockwise a small turn to lock it in. If you have big hands... its tough...
JayW
JayW
ghettocowboy94
