QA1 10-350 10" springs
R
rigo_jones
going against
DENVER mexico
thanx goodluck.. it a lot of time and searching but paid off in the end...
does any1 know the size of a djm or belltech 5 inch spring with full weigh on?
Badluck
SE WI
McGaughy 5" coil sits at a hair under 8". I don't have a spare tire or 3rd row seat.
I need another 2 inches out of the back for the truck to sit level.
R
rigo_jones
going against
DENVER mexico
u serious? thanx bro im gonna go with a 9 inch coil then. was this with full weight on?
Badluck
SE WI
Yes. All I have in the back of the truck is the stock suspension parts. If you get 2" compression I would need a 8" coil. I plan on doing a c-notch anyway.
R
rigo_jones
going against
DENVER mexico
yup 8 inch for you. i want to notch it too, have u been in an air suspension car/truck before? im wondering if the ride quality is good with airbags. thanx again for the info bro.:Handshake:
Badluck
SE WI
Never ridden in a bagged ride. My plan is to bag the rear of my truck. I bought all I need from a fellow tyf member but am still waiting for the parts from him. I am just going to use schrader valves, no compressor. I am hoping that the bags will smooth out the ride, especially since I want to go 2 inches lower than the 5" drop coils I have now. I'm also going to make an adjustable panhard bar to get the rear wheels centered.
R
rigo_jones
going against
DENVER mexico
i hear you i was thinking of doing the same my self but dont know yet u should do a write up or post some pics of the install i might copy you. lol :)
Max
Mile High
Denver
Where did you measure from? My belltechs don't sit that low and I was the same height as a friend's denali with the 3/5 mcg kit with identical height tires before I pulled my isolators. I think the 9" qa1 450 springs are gonna be the ticket for a 7" drop, guess there is gonna be some trial/error involved with these things. Thank god for summit's return policy lol.
Badluck
SE WI
Max
Measured driverside from bottom of upper mount to top of bottom spring mount.
I plan to do a write up when I do the install. I can't take credit for the idea, found it here just search set it and forget it.
TEXAS DEMON
with a vengeance
texas
on the pan hard go to www.suicidedoors.com. they have adjustable links at a very good price.go to the 4 link parts section. the oem bar is 33.5" so i need something that is 1" to 1.5" shorter
BrancoRST
