So as some of you may be aware at 160k I decided to have the dealer replace the u joints.
Well they fubar'd that to hell and upon picking the vehicle up immediately upon getting on the freeway I had some pretty bad vibration they were closed and so I limped it home about 10 miles at 55 to keep the vibration to a minimum, I had it towed back to the dealer and they replaced one u joint that was jacked up. Still had some vibration so I had the drive shaft re balanced and that helped a bit. At this point I now had some good amount of slop enough that it feels like the rear end is dipping when I accelerate and I can feel it when I brake as well, no clunk noise but I can feel it. So I drove it like that for 2500 miles and this hasn't changed. I ordered a new drive shaft because I figured maybe the slip yoke was f-ucked and maybe a shaft ear. Got the new drive shaft in and vibration is all gone but I still have the slop now and had none before this at all. So my question is could this vibration have messed up the transfer case and or pinion/carrier in the few short miles it was driven. And is there a way I can tell if it is the transfer case or rear end? Like is there a minimum amount of play that would tell me if one has more than it should or not?
I'm assuming I will have to drop the drive shaft and see which end moves more?
