question about rear defrost
ottis
What would cause the drivers side rear defrost not to works. I dont see wires going to the door. Any advice?
96redsport
Altoona, Pa.
Check the contactors on the top corner for dirt and/or corrosion. Had same problem before and they worked after I cleaned them up.
96redsport
Altoona, Pa.
I have a small section that doesn't work even after I cleaned them so I guess I will replace the contacts next.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Are there any broken lines? Such as, is all but one line working?
If a small section is not working, more than likely, the trace is broken on the glass. You can grab a defroster grid repair kit at local auto parts store. Much cheaper than new glass. This may help-
http://www.popularmechanics.com/cars/how-to/maintenance/4221212
Yes, Permatex, which is a brand carried at about every parts store has this. Send me a PM and I'll try to get you the part number tomorrow.
Sent from my myTouch_4G_Slide using Tapatalk
96redsport
Altoona, Pa.
It's about 3 lines together. Didn't know if there were "zones" on the grid. I don't see any breaks tho.
BrancoRST
